Orbi WiFi 7 RBE973
Reply
Help Stuck In Bridge Mode
Kuroodo
Tutor
My modem lost internet so wanted to connect router to mobile hotspot until it got fixed. I didn't enter the hotspot password when enabling bridgemode and now my router is stuck.
I can't access the routerlogin to disable bridgemode. I've pressed the reset button for 10 seconds and even 30 seconds. Can't get it to work.
How do I get out of bridge mode or at least access my router settings?
Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Accepted Solutions
Kuroodo
Tutor
Re: Help Stuck In Bridge Mode
After resetting my router and restarting my PC for the 80th time, it started working again.
Nothing to see here I guess...
Message 4 of 5
All Replies
antinode
Guru
> [...] I've pressed the reset button for 10 seconds and even 30
> seconds. Can't get it to work. [...]
   What, exactly, happens when you try that?  Do the LED indicators
indicate anything interesting?
   You might also try doing the reset (and ten seconds should be long
enough -- watch the LED indicators) with nothing connected to the router
(except its power adapter).
Message 2 of 5
Kuroodo
Tutor
Well when holding down the button, the power led starts blinking orange. When letting go, my router starts doing some light display for a few seconds and then everything goes off and power led goes orange. Then some of the lights come back on slowly
Message 3 of 5
Kuroodo
Tutor
Message 4 of 5
It is slowly rebooting itself and running through various checks before it establishes a connection with whatever modem sits in front of it.
Remember, when playing around with a mix of devices you need to reboot the network in the right order.
  • Turn off and unplug the modem.
  • Turn off the modem router and computers.
  • Plug in the modem and turn it on. Wait 2 minutes.
  • Turn on the modem router and wait 2 minutes.
  • Turn on the computers.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 58393 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
