Reply
Highlighted
Help settign up my home network
I have 2-R7000 Routers & 1-EX7000 extender. its a normal house 2 floors plus basement  (top floor- main floor- basemnet)
internet connection (modem) is in the basement (i can get a cable cable between the basement and Min floor)
Network usage: Stream TV services, Inernet use, etc on all flors
My Quesions:
1. How should I set up each device - bridge mode, (AP mode) access point, repeating mode
2. Which device should be on each floor
3. should they have the same network wifi name.
Your assistance would be greatly appreciated, thanks in advance
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Highlighted
Re: Help settign up my home network
Put one R7000  in AP mode (wired to the router) or as part of a Wireless Distribution System (with wifi link to the router).
There are conflicting ideas on that one. Try it and see?
Again, suck it and see, but if possible I would put one wifi source within wired distance of any smart TV that has a LAN port. Then you can plug the two together, which is easier to set up and more reliable than wifi.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Highlighted
this is what I did
connect the router to my modem setup my wireless and guest network. Connect a LAN cable from this router to main floor R7000 using the wan/internet port, set it up at an AP, it asked me to disable the wireless on the main route?  I did,  should I have?
used a 2nd LAN cable to connect the EX7000 also, set the EX7000 up as an access point
used the same wireless name  for all 2.4 & 5G in both devices
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 343 views
  • 0 kudos
  • 2 in conversation
Announcements
