Orbi WiFi 7 RBE973
Reply
Help setting up DM200 and MR60 Mesh
Auswi7797
Follower
Hello I am using Fibre to the Node Broadband and need help setting up my home network.
I want to use the DM200 to receive the internet then pass it through the Mesh MR60 router plus its 2 satellites which is connected via a switch to devices using ethernet and wifi. My question is.
Do I leave DHCP on in the DM200 and turn it off in the MR60 netgear mesh router or do I turn off DHCP in DM200 and turn it on in the MR60.
When I originally set it up every Web page was being redirected to the internal MR60 login page.
Help very appreciated
Wayne
Model: DM200|Broadband High-Speed DSL Modem
Message 1 of 5
Accepted Solutions
Guru
Re: Help setting up DM200 and MR60 Mesh
The MR60 is a more capable device.
I'd setup the DM200 in modem only mode (disable its router functions) and run the MR60 in router mode.
Message 2 of 5
All Replies
Guru
Message 2 of 5
antinode
Guru
> Do I leave DHCP on in the DM200 [...]
   DHCP is not the critical thing.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Disable the
Modem's Routing Features and Use the Modem as a DSL Modem Only".
Message 3 of 5
That's the way to do it.
I chip in simply to provide some feedback as a DM200 user. In modem only mode, the DM200 is hard to get at. (No obviously accessible IP address on the local network.) So update the firmware before you bite the bullet. And create a backup of your settings, just in case you need it later.
The manual for the DM200 explains the implications of accessing the thing in modem mode, but with luck you won't need to get into it.
Message 4 of 5
antinode
Guru
> [...] In modem only mode, the DM200 is hard to get at. (No obviously
> accessible IP address on the local network.) [...]
   Do you mean that the "IMPORTANT:" suggestion in the User Manual does
_not_ work?
      You can now access the modem only through a fixed IP address,
      which is 192.168.5.1.
   It doesn't _look_ complicated.
> thing in modem mode, [...]
   "implications"?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1237 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
