Reply
Help with brand new x6 ac3200
Jimhill78
Hello,
I just bought a Nighthawk x6 ac 3200 tonight and am having issues.
My phone cannot find the router with the app, even when signed onto the network.
Second, the Genie will not sign in on my pc to change router settings, it just hangs with a loading wheel.
Third, my speeds are 80 whereas I usually get 250.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
microchip8
Master
Re: Help with brand new x6 ac3200
which app are you using on the phone? Highthawk or Genie? I suggest using the latter
Also, the router is best configured using its WebGUI at http://192.168.1.1
Further, if you have QoS enabled, disable it
Routing: NETGEAR RAX43 - Firmware: v1.0.11.112 (1 Gbps down, 50 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 4
Jimhill78
Using Nighthawk.  Used the 192...to configure. Dont have QoS enabled.  I just did a reset and speeds MAYBE went up? Checking hardwired tho
Message 3 of 4
Jimhill78
also, trying to log in on my phone with Genie just hangs on loading
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 422 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
