Reply
Home size
pierre22
Home size
Hi, the modem Nighthawk x4s AC2600 VDSL support is sufficient for a house on 3 floors?
Thanks
Message 1 of 7
TheEther
Guru
Re: Home size
In my personal opinion, I think it will be unable to provide good coverage throughout the entire house.  If you are able to place the router on the second floor, out in the open, then perhaps it will work.  But I still think the speeds won't be very good.
Message 2 of 7
pierre22
Re: Home size
the modem operates one or more dynamic dns?
Message 3 of 7
JamesGL
Master
Re: Home size
Hi @pierre22,
Welcome to Community!
The router supports 3 Dynamic DNS. These are No-ip, Netgear and DynDNS.
JamesGL
Community Team
Message 4 of 7
mistikempire
Guide
Re: Home size
What would you do? As im having a problem where i had the r7500 an wasnt happen with the cover my home which is also 3 floors
Message 5 of 7
JamesGL
Master
Re: Home size
Hi mistikempire,
Where is the router located?
Until which floor you can detect the signal? How far is it when it comes to distance?
With 3 floors you may need to have extender in order for the wireless range to cover areas that no longer detects the wireless signal.
Message 6 of 7
mistikempire
Guide
Re: Home size
The house is:
LOFT Conversion (My room, oled 4k smart, ipad, laptop, iphone = signal is very good, like the 2nd floor)
2nd Floor (2 Bedrooms, 1 small computer room = this is where the router is, it is connected to the desktop)
GROUND FLOOR (Smart 4k tv, Laptop = now this is the floor which has the most problems)
I think the reason the loft does not have any probs as their are no main walls right in the middle, as they are all plasterboard.
However the ground floor has a main wall right in the middle
Now my R7500 has literally been taken back, so i am in need of a new router anyway, so its either the ASUS 3200, ASUS RT-AC87 or the NETGEAR X6 R8000
I might aswell buy something with a good range, an like you said, buy a range extender...an also lastly, would upgrading to fiber optic at the same time help?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2387 views
  • 0 kudos
  • 4 in conversation
Announcements
