Reply
Horrible download speed on R7000 with 1.0.9.x firmware
tmorrow411
I have a R7000, and on my mobile devices, I get about 50/200 mbps on Speedtest.net, when using 1.0.9.12 firmware.  My laptop would usually do better at 200-250 up/down.
I have a fiber 1000 Mbps connetion, and tested the following and here are my average speeds with each on my devices using 5 Ghz.
Mobile devices: reported connection of 866Mbps.
  • 1.0.9.12 = mobile:50/200, laptop: 200/200
  • 1.0.9.10 = mobile:50/200
  • 1.0.9.6 = mobile:90/130  (would sometimes go up to 150)
  • 1.0.8.34 = mobile:200/200, laptop: 330/200
  • 1.0.7.12 = mobile:220/220
  • 1.0.5.70 = mobile:220/220
 Mobile Devices:  Moto Z Droid, LG Tab 8, Kindle Fire HD 8, iPhone 7, iPhone X
So why would the newer firmware impact my mobile devices primarily?  I do see some impact on my laptop as well, but the biggest impact is definately my mobile devices.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Re: Horrible download speed on R7000 with 1.0.9.x firmware
The first thing to do with a 1000 MBps service is to disable QoS. You don't need it.
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Start at page 47.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
tmorrow411
Thanks for the feedback.
As stated, the issue lies within the firmware version.  Starting with the 1.0.9 series, and primarily 1.0.9.10, wifi download speed suffers.
But to answer your question, QoS was disabled in all tests.
Message 3 of 4
JamesGL
Master
Hi tmorrow411,
Please check your inbox.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 925 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
