- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I add a TP-link extender to ORBI RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I add a TP-link extender to ORBI RBR20
it won't mesh with the systems because they're not compatible.
But you might be able to install the tp-link device manually. you'd be best to check with the tp-link forum/support on how to manually install the tp-link device instead of using wps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I connected a TP-Link N300 extender to my Orbi, I followed the instructions in the TP-Link user manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should add that to ensure that the device connects to this WiFi extender rather than to the Orbi, the TP-Link should broadcast a different WiFi SSID than the Orbi. Extenders usually have two 'modes' (1) broadcast the same WiFi SSID, or (2) broadcast a different SSID.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should I reconnect the extender and connect the device to it again rather than the Orbi? And then how to I go about connecting the extender to the Orbi system? Sorry I’m a bit new to all this so apologies for all the questions. I just want the device to work better even though the coverage is excellent with the Orbi. It just doesn’t like the Orbi system in Live view.
