Reply
How do I roll back to a previous firmware?
ESILVER
Initiate
Where do I find the firmware file to rollback to and how can I see what my previous version was?
Thanks in advance.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Accepted Solutions
IrvSp
Master
Re: How do I roll back to a previous firmware?
Quite EASY... on the top, click on SUPPORT. Then enter your ROUTER model, R700 and click on the proper model that shows and press enter. Next screen, click on DOWNLOADS. At the end of the list is PRIOR VERSIONS. One the one you want you see a '+'. Click on that and there are TWO links. Click on the README and just FOLLOW those instructions.
Message 2 of 3
All Replies
IrvSp
Master
Message 2 of 3
ESILVER
Initiate
Perfect. Thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 33130 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
