Discussion stats
  • 3 replies
  • 3623 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
How do i block an IP address in R7000?
How do I configure R7000 to block an IP address? I want my router to ignore this IP address: https://twitter.com/manfightdragon/status/823740044682805249/photo/1?ref_src=twsrc%5Etfw
I just can't seem to find where to configure it.
Thanks in advance!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Highlighted
Guru
Re: How do i block an IP address in R7000?
Go to ADVANCED > Advanced Setup > Static Routes and set up the following static route:
Destination IP address: 111.119.22.0
IP Subnet Mask: 255.255.255.0
Gateway Mask: <an unused IP address on your home network>
Metric: 1
This will technically block traffic in the outgoing direction by sending it to that unused address.  This should be good enough to effectively block communication with that destination.
Message 2 of 4
Highlighted
Thanks, I will try this!
I am wondering though, would my PS4 try to connect to an alternate IP address just like in this tweet:
https://twitter.com/manfightdragon/status/823740173749882880
or will it try to connect to my unused IP address entered in the Gateway Mask?
Message 3 of 4
Highlighted
Guru
Presumably, the PS4 decided to connect to 111.119.22.0 because an address in that network was returned in a DNS reply. A DNS reply can contain multiple addresses. The PS4 can try connecting to those other addresses or it could try sending a DNS query for another domain. That's up to the PS4 to decide.
I will say that this whole idea is kind of a hack to work around poor distribution of the servers. But, hey, if it works, then more power to you!
Message 4 of 4
