Reply
How do i change my router channel to 6?
SRpancakes
Follower
I went to routerlogin.net --> wireless --> channel so far my is set to 153. When using my wifi analyzer app it read channel 10. I tried messing around with it on my phone but it still read channel 10.
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
Guru
Re: How do i change my router channel to 6?
Channel 153 is your 5ghz channels. Above that should be the settings for the 2.4ghz. Its probably set to auto if its on channel 10.  Look for the 2.4ghz settings
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 569 views
  • 0 kudos
  • 2 in conversation
Announcements
