- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How many IP addresses can be reserved on an Nighthawk X6 (R8000)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am looking to allocate IP addresses for all my devices on the network so does anybody know if there is a limit on how many devices can be added to the Address Reservation table?
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How many IP addresses can be reserved on an Nighthawk X6 (R8000)
I have about 20 reserved on my network and have not had any issues. I don't believe there is a limit to the number you can reserve.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Is that accurate? Firmware version?
> [...] does anybody know if there is a limit on how many devices can be
I assume that there is one, but I have no reliable info on what it
might be. The following (low-quality) report might be interesting:
https://community.netgear.com/t5/x/x/m-p/2053443
A Web search might find other/better reports.
Did you consider offering any clues as to how many devices you might
have? Or whether you're seeing a problem?
I have 24 on my D7000[v1] (V1.0.1.78_1.0.1).
> [...] I don't believe there is a limit to the number you can reserve.
I don't believe that unlimited storage is a property of the R8000.
With a "/24" subnet, 253 would seem to be a pretty firm limit. I would
not be amazed to see problems well before that.
If I cared, and I had the device in hand, then I'd run the
experiment. I'd expect that result to be more reliable than any info I
might find here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Many thanks for the comments.
It is the latest firmware - V1.0.4.68_10.1.75
I dont currently have a problem as I am installing this router to replace a prevous setup. I have around 60 devices with mixture of wired/wireless or both. Am looking to give them an address so as to make known devices more easy to identify and whether on wired or wreless connection and soem devicxes I need a fixed address on.
On a previous router I hit a limit around 20-24 devices so before going to the effort of trying configuring them all on this one I thoght I would see if anybody is aware if there is a limit.
The article was useful and it does not look like there is any certainty on numbers supported (appreciate the overall limit of 253 on a /24 subnet). As per your comment I will give it a go and see if there is a restriction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have now entered the IP address reservations and the limit is 64 on this router.
Regards
Peter
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] the limit is 64 on this router.
Interesting. What happens when you exceed it? Error message, or
some kind of bad result, or what?
