Orbi WiFi 7 RBE973
Reply
How to Get a Detailed Internet Usage for Netgear Nighthawk R7000
Reaper822
i have been trying to get a detailed internet usage for my network so i am able to see what devices are uising the internet and how much.  is this possible on the model i have.  The router is using the latest firmware version V1.0.1.44_1.0.1.
Thanks
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Accepted Solutions
TheEther
Guru
Re: How to Get a Detailed Internet Usage for Netgear Nighthawk R7000
You can get per-IP traffic stats with third-party firmware, Asuswrt-Merlin.  Note, you will lose hardware acceleration, so the max throughput between WAN and LAN will drop to about 450 Mbps.  If you have Gigabit speed Internet, then there may be a noticeable drop in performance.
The usual caveat emptor applies for third-party firmware.
Message 4 of 6
All Replies
Guru
Have you enabled Traffic Meter feature on the Router?
Message 2 of 6
Reaper822
Yeah I have but that only gives an overall usage. I want to know how much each device is using
Message 3 of 6
TheEther
Guru
Message 4 of 6
Guru
Might try OpenRouter FW as well, however not sure if they support per device stats as it's mostly the same UI. Might beable to though.
Message 5 of 6
Reaper822
Thanks theether will try that
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3406 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
