Reply
How to I revert back to old Firmware?
Haywire
Thanks in advance for any help you can provide.
I purchased the R8000 router around April 15th. I read about some flakey software but I figured they would push out an updated and fix it and sure enough they did and the router worked great! Well... a week or two ago they pushed out another Firmware update and my router has been horrible every since.
About once or twice a day my internet connection slows down to almost nothing. If I test on the router itself though using the speedtest tool it measures 300mb/20mb... but if I test through the wifi it's about 2mb down.. and even that 2mb is slow enough to be unusable.
I'd like to just revert back to the old firmware I was using before this more recent "update" and change the settings to prevent new firmware from auto updating and killing my internet connection.
Any help? Possible? Thanks!
Message 1 of 4
Babylon5
NETGEAR Employee Retired
Re: How to I revert back to old Firmware?
You just need to follow the normal upgrade process, but ignore any warning that you are about to install an older version.
I suggest that you factory reset the router after the firmware change and re-enter settings manually, so note down any non-default settings before you begin.
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 4
Retired_Member
Not applicable
Download older version from support site unzip if zipped and then browse to saved location an you haand select and ignore older version warning.
I always thought the "normal" to be when the router notified user that a update was available.
Lastly just because A update is available it doesn't meve to install it.
Message 3 of 4
Fairytail
Virtuoso
For step by step process, check this KB article.
http://kb.netgear.com/app/answers/detail/a_id/23960
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 58474 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
