Reply
How to View Signal Strength of Wirelessly Connected Devices
atomicUpdate
Follower
Is there a way to view the signal strength and/or the connection speed of each of the devices wirelessly connected to the R7000? I'd like to use the information to determine the best place to put a wireless bridge and the direction to face it.
Message 1 of 12
Rheumatoid
Re: How to View Signal Strength of Wirelessly Connected Devices
use genie or another app on a mobile device and wander around with it
Message 2 of 12
theoak
Luminary
inSSIDer will also work (I hear you have to pay for this guy now though.)
RBK53 v2
Router Firmware: 2.7.2.104
Satellite Firmware: 2.7.2.104 (Satellite1: Wired, Satetellite2: WiFi)
Setup: DSL Modem (Bridge Mode) - Personal Router - Orbi (Access Point mode)
Message 3 of 12
Retired_Member
Not applicable
Look for inSSIDer version 3.1.2.1. It is the last free version.
Message 4 of 12
jmizoguchi
Virtuoso
http://www.metageek.net/support/downloads/
older version still is free
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 5 of 12
Retired_Member
Not applicable
I did what a mistake that was. Look for version 3 it's free the only difference is 5gAC support.
They claim netgear's Beacon is broadcasting a non-standard beacon or something close to that. This is the reason they give for the 5g AC support not displaying max rates correctly. That being said v4 is worthless.
Message 6 of 12
IrvSp
Master
Rheumatoid,
Genie shows me the various connected devices on the network map, wired devices only shows that it is connected, but wireless device connection speed and power you get when you click on the device. No need to walk around with it.
Message 7 of 12
RogerSC
Virtuoso
If you have an Android phone or tablet, the "WiFi Analyzer" app is free, and works well for me. I have an Android phone and an iPad, so I'm pretty much stuck with Android apps for this. Apparently Apple wants no part of helping me to optimize my wireless network set up.
Message 8 of 12
Jim769
Luminary
Agree strange wifi analyzer use to work with apple some time ago. Have no idea why apple don't allow it any longer.
Good to see you on the forums Roger. Still waiting for Comcast to fix the neighbor over flow issue. :rolleyes:
Message 9 of 12
Retired_Member
Not applicable
Apple doesn't want to reveal the APIs and drivers for their wireless chipsets. There will likely never be wifi analyzers on IOS.
Message 10 of 12
jmizoguchi
Virtuoso
You can do heat map with Oscium Wipry which used external device with it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 11 of 12
Retired_Member
Not applicable
I may have missed it, But have you actually tested the link lately. It appears the geeks now only offer a 5 day trial.
check it out
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 11149 views
  • 0 kudos
  • 9 in conversation
Announcements
Orbi WiFi 6E
