Orbi WiFi 7 RBE973
Reply
How to add the AC1200 WiFi Range Extender to the AC2200 Tri-Band WiFi Range Extender?
TL35537
Source:  Verizon WiFi device
First extender:  Netgear Nighthawl X 4S AC2200 Tri-Band WiFi Extender (Model EX7500)
Question:  How can I add my old AC1200 (model EX6150) for use inside my bedroom?
Message 1 of 5
Guru
Re: How to add the AC1200 WiFi Range Extender to the AC2200 Tri-Band WiFi Range Extender?
so you're currently going:
Verizon wifi device (model?)---->EX7500
and you want to conenct another extender to the EX7500
What error/problem are you running into?
You can daisy chain extenders. I wouldn't recommend doing it but it can be done.
Message 2 of 5
TL35537
Yes, that's exactly what I am looking to do.  The Verizon router is all the way in the living room.  The EX-7500 is half way in the middle of the apartment.  I need to put the EX-6150 inside my bedroom, which is at the end of a long hallway.
How do I configure it?  Thanks in advance for your help!
Message 3 of 5
Guru
@TL35537 wrote:
Yes, that's exactly what I am looking to do.  The Verizon router is all the way in the living room.  The EX-7500 is half way in the middle of the apartment.  I need to put the EX-6150 inside my bedroom, which is at the end of a long hallway.---dual/single band extenders cut throughput 50% by the very nature of how they work. If your computer is in the same room as the (EX6+++ extender, you'd be better off connecting directly to the EX7500.
How do I configure it?  Using the same guide from the installation support site.
Message 4 of 5
TL35537
My laptop is currently connecting to the EX7500 device outside the bedroom but the connection drops from time to time.  That's why I want to have another extender inside the room.  Let me take a look at the installation guide and figure it out.  Thanks!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 866 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
