Reply
How to assign a static IP address for my PC
Hi guys. I use my office PC as a movie server. I would like to put my PC to sleep and use a wake on LAN app on my phone to wake the PC instead of going into the room to turn the PC on. The PC needs to have a static IP address for the app to work.
Is this easy to do with the just the router itself? Does it matter if my PC is on a switch? Anyone have the time to walk a newbie through the steps?
Master
Re: How to assign a static IP address for my PC
What are you using to run the network? Which modem/router? R7000?
That will have ways of fixing an IP address. Look in the manual. Page 100-101.
What are you using to wake up the PC? It is often possible to use the PC's mac address to wake up something.
Modem Router: D6400 (Firmware V1.0.0.58_1.0.58.chk)
Powerline:XWN5001, XAVB5101, XWNB5201, XAVB5421
WiFi: WN2000RPT, WNDA3100
Ethernet Switch: GS108v3 ProSafe 8-Port Gigabit
Security camera: Arlo Q Plus
Prodigy
First - static addresses are set at the PC, and are what are known as logical addresses, dependent on the PC's operating system to be running - what this means is when the PC is off, the OS is not running and it has no ip address.
For this reason Wake-on-LAN does NOT depend on ip addresses, and any Wake-on-LAN application that requires an ip address is poorly written - the MAC address of the PC's network adapter is what is required - please be aware that both the network adapter and the PC BIOS must support Wake-on-LAN for it to work.
Assuming you're running Windows, open the network adapter properties, select tcp/ip and go to properties, you can enter the ip address there.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Thanks for the replies guys. I forget what app it was. But it was about a year ago when I tried it. It did work with my rig but my landlord had control of the router and the IP address kept changing. Ff a year later, bought a house and trying to learn all I can about networking and sharing files across many devices and pcs in the house.
I'm using win7 x64. Bios supports it. Using the nighthawk r7000.
If I can use a wake on LAN app that uses the MAC address instead of requiring a static ip that would be even easier. Can you guys recommend such an app? I have iOS devices. I will look too. Free is me but if it is worth it I don't mind shelling out a few duckets. Thanks.
Luminary
There is few app in iOS that free for paid on network utility that can do wake up your LAN device when you are the same network
I would suggest to use static IP any way something that is permanent .
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
jmizoguchi, why is it that every time you reply to one of my posts you do nothing more than just repeat my question. Can you recommend any apps? Can you recommend a common way that people configure their pc to haver a static ip address? Don't mean to be nasty.
Looking for help.
Luminary
I'm not repeating
Good luck
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Retired_Member
For WOL I use RDP Lite it's free app I use on a 4s, locally only.
Tutor
To setup Static IP's use, Advanced, Setup, LAN Setup.
I always setup the DCHP server to handout IP's in a range of 51 to 250.
I then assign static IP's in the range 2 to 50.
Using this method ties the MAC address to the static IP.
You will need to reboot the router once you have made the changes.
Reboot the PC (or renew the IP with ipconfig) to assign the new fixed IP.
Assigning a fixed IP on a laptop via the network adapter in control panel is not a good idea as you will have to change it if you travel.
Master
In light of the fact that few of the replies here are directly related to the question, I will throw in another off-topic suggestion, albeit one that is in tune with "trying to learn all I can about networking and sharing files across many devices and pcs in the house".
A good WOL app for a PC is: WakeMeOnLan from Nirsoft.
For PCs I'm afraid. But you never know when you may need this function. This will also tell you the MAC addresses of stuff on your network.
Here I used to fix IP addresses for everything, but then decided to restrict it to things where I do need to know the IP address to login. For example, I have a bunch of NAS boxes. Then again, I wake them up through their MAC addresses.
It can also help to fix the IP addresses of wifi repeaters for the same reason. But you can often get at these by looking up the IP address in the network map and going in that way.
Prodigy
What you are describing is a DHCP reservation - static ip addresses and DHCP reservations are not the same thing - a static address can only be set at the host. The big difference is that a static address will work in the absence of a DHCP server.
Tutor
Of course it's DHCP reservation, DHCP reservation ensures that a given MAC address always has the same IP when on the network. It's static while on your home network and can change when not.
Thanks guys. Here is what I did: I forked over the $7 for the app "iNet network scanner". It includes a WOL. It automatically scans my network, finds my pc and sends the wol command. It works very well. I also set my computer to have a static IP by right-clicking on the network adapter, IP4 settings, "Use the following IP address". I just used the one that it was currently using, it filled in the subnet mask, and the routers internal ip (192.168.1.1) as the default gateway. I also changed the DNS to google 8.8.8.8. an 8.8.4.4..
The iNet app scans the network so I probably didn't need to do all this but I wanted the same ip address for this pc so I can identify it on the network.
Did I do the static ip correctly? I didn't go into the router at all. So far, it's been about 5 days and its working great. However using ipconfig /all shows that DHCP is off. Is this ok?
-------------------------------------------------part2------------------------------
Now, to wake my pc from the internet, the app needs to know the host ( ip address/DDNS hostname). Now if I just use my public IP address this is going to change eventually so I need to use Dynamic DNS? I did a little research but im in unfamiliar waters.
I have to install this dyndns software? And by doing this I am making my network vulnerable.
I was wondering if there was an alternate way to configure this in the router? I'm not comfortable with making my network vulnerable. I share all my movies, music, photos on the server pc (the one with the static ip) with the whole network.
Thanks. Still learning.
Prodigy
I hate repeating myself - static ip addresses and DHCP reservations are not the same thing - static ip addresses work in the absence of a DHCP server, DHCP reservations do not - "home network" or not. There is a time & place to use a DHCP reservation, and a time & place for static addresses - a host that's acting as a server is the time use a static address.
Discussion Stats
  • 13 replies
  • 9164 views
  • 1 kudo
  • 6 in conversation
Top Contributors
