Orbi WiFi 7 RBE973
Reply
How to block porn from search engine
1_C4T4LY5T
Hey crew,
I turned on the parental control filter for my Nighthawk R7000P and am trying to block all porn. It does a good job, however, I have noticed that you can still do a search in Google or similar search engine and click the "images" tab to view thumbnails of porn that was searched. Yes, you cannot click on the image to bring up the site but you can still see images. Would anyone on here know how I can prevent this in search engines from my router filter either natively or by installing 3rd party software?
Thank you for your time and consideration
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: How to block porn from search engine
Hello,
The R7000P does not support this feature. You may want to look into our Circle parental control service.
https://www.netgear.com/landings/circle/
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2986 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
