Reply
How to change Security questions for admin password recovery without doing factory reset in the rout
LoneStarQ8
Follower
How to change Security questions for admin password recovery without doing factory reset in the router?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: How to change Security questions for admin password recovery without doing factory reset in the
   I've never used password recovery, so I know nothing, but on my
D7000[v1] (V1.0.1.64_1.0.1), at ADVANCED > Administration > Set
Password, there's an "Enable Password Recovery" check-box.  Can you
un-check+re-check it?  Otherwise, I'd try (on that same page) setting a
new password, which I'd expect to offer a new chance to "Enable Password
Recovery".  (But what do I know?)
Message 2 of 2
Discussion stats
  • 1 reply
  • 4083 views
  • 0 kudos
  • 2 in conversation
Announcements
