Reply
How to configure my Nighthawk X6 R7900 to handle 200 mbps download speeds
soggyoggy
Follower
How do I configure my Nighthawk X6 R7900 to handle 200 mbps download speeds?  I am currently getting 94.86 mbps through my router.  When I connect my modem to my desktop I get 240 mbps.  When I run the speed test in the Genie Dynamic QoS it shows speeds up to 212 mbps upload at 12.20 mbps.  I have Comcast ISP and their speedtest shows 94.86.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
LeeH
Prodigy
Re: How to configure my Nighthawk X6 R7900 to handle 200 mbps download speeds
I am getting 350/23 out of my R7900 on a 300/20 connection.   I reset the router changed the admin password and reserved all my IP addresses.  I have never turned on QOS but would do another reset using the button on the back if I did turn it on.  The fastest internet speed you can get from a Netgear router is almost always by using the default configuration.
Have you tried using http://www.speedtest.net/ ?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1674 views
  • 1 kudo
  • 2 in conversation
Announcements
