Reply
How to connect Hotspot to router
DampSock1
Follower
Hi, I need help connecting my Verizon MiFi 6620L device to my Nighthawk AC1200 WiFi router Model#R6120. Reason is I want to expand my range for WiFi use in my household. The MiFi device does not have Ethernet port but does allow to tether through USB. If anyone can help and be detailed as possible. I have checked sources online but nothing. Thank you.
Message 1 of 2
IrvSp
Master
Re: How to connect Hotspot to router
Might want to check the Verizon forums for this?
Every thing I've seen has you connecting directly to the router via Ethernet or USB. In most cases this would have it close to the router and it probably wouldn't help for coverage? Netgear routers with USB ports probably wouldn't support the device as well?
Am I missing what you want to do?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1013 views
  • 0 kudos
  • 2 in conversation
Announcements
