Reply
How to disable remote management R7000 nighthawk
Larrydot
I received the netgear e-mail, but cannot figure out how to ensure the remote management is disabled?
Message 1 of 4
Retired_Member
Not applicable
Re: How to disable remote management R7000 nighthawk
Then it's probably not enabled, login to router, it's under advanced setup.
Message 2 of 4
aisthesis
Could you be more specific. There's a lot under 'Advanced', and I'm still not finding that particular configuration.
Message 3 of 4
JamesGL
Master
Hi All,
The remote management is under advanced>advance setup. Uncheck it if you are not goint to use it.
http://kb.netgear.com/app/answers/detail/a_id/24234/~/how-do-i-set-up-remote-management-on-my-nighth...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5523 views
  • 1 kudo
  • 4 in conversation
Announcements
