Reply
How to disable wireless radios on the Nighthawk R7000
jj909
Follower
Which menu contains the ability to disable the 2.4 GHz radio? I'm not seeing one.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
HiSpeed
Guide
Re: How to disable wireless radios on the Nighthawk R7000
Hi,
Advanced/Advanced Configuration/Wireless Parameters !
● Netgear R7000 (Root Router)
● TP-Link Archer C7 v2 (WDS Bridge)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1369 views
  • 0 kudos
  • 2 in conversation
Announcements
