Reply
How to factory reset?
Liv03
Follower
I no longer need my router so I need to factory reset so someone else can use it... I don’t know how to factory reset??
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 4
microchip8
Master
Re: How to factory reset?
There's a Reset button at the back. Press it for 7-10 seconds and release.
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.89SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 4
Not so much a button as a hole in the back – look for the "Reset" label – that you can attack with the end of a paperclip.
Press it with the power on.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
microchip8
Master
That's still a button, placed in a hole. When you push it, it makes contact
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 309 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
