Discussion stats
  • 3 replies
  • 306 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
How to get the best wireless connection channel with 2.4ghz and 5 ghz
What channels are the best to use for 2.4 ghz and 5 ghz to get the best performance cause it is dropping a lot
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 4
Highlighted
Master
Re: How to get the best wireless connection channel with 2.4ghz and 5 ghz
use a wifi scanner on your phone/laptop and use the least used channel
your connection drops migh be from something else, though
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.79SF
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400
Message 2 of 4
Highlighted
Which scanner app do you recommended?
Message 3 of 4
Highlighted
Master
I use WiFiAnalyzer on my Android phone
Message 4 of 4
