Orbi WiFi 7 RBE973
Reply
How to handle the routing
attilay2k
Good morning all
i've just bought a GS324T to handle my devices by using VLANs.
i can't figure out how to set routing on the switch; I would like to enter the classic routes for the VLANs: (the gateway, which for each VLAN will be the last IP 254), and the default route 0.0.0.0 which must rotate all the unknown traffic towards the router 192.168.xx, and then towards the internet
I can't find the section of the GUI in which to make this setting, In my old M4100 (GSM5212) I had a special tab to manage routing (and also DHCP, which I can't find here)
Is there someone who can help me?
Thanks in advance
Regards
Model: GS324T|NETGEAR® S350 Series 24-Port Gigabit Ethernet Smart Managed Pro Switch with 2 SFP Ports
Message 1 of 2
Re: How to handle the routing
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but switches have very little, if anything, in common with routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 365 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
