- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to have the CM1100 providing network for two Wi-Fi routers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to have two different Wi-Fi routers connected to the CM1100. My plan is to have one WRT Wi-Fi router connected to a VPN (NordVPN) and let the other (AMPLIFI HD) not connected to any VPN. So I can watch Netflix from the WRT Wi-Fi router from any other country, while using my AMPLIFI to connections without the use of a VPN.
Is it possible to have a switch connected to the CM1100 and then the two routers connected to the Switch?
Any other solution you see?
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The CM1100 has 2x ethernet ports. the problem isn't the modem, its the ISP. Most of the major ISP's only allow 1 public ip address for consumer lines. So you can only connect 1 device.
You can pay for more IP addresses or upgrade to business class to get more with some of the ISP's. If you do that, then you could attach more than 1 device (not through a switch though).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to have the CM1100 providing network for two Wi-Fi routers?
