stevekauss
Feb 21, 2021Aspirant
How to reset OpenVPN to disable old users
I had some users using VPN to connect to my netwlork earlier so they have the openvpn cert and config files to connect to my network. Now they don't need to access it anymore. How can I disable VPN access for these users but still keep the VPN access enabled for myself. I don't see an option in R7000 vpn config page to generate new set of certs. Is there another way to do this?
1 Reply
- DarrenMSr. NETGEAR Moderator
You may want to check out this openvpn link
DarrenM
