- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to set NighthawkR7000 to repeater mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I just bought a netgear Nighthawk R7000 (AC1900 Smart Wifi)
and am trying to figure out how to set it to REPEATER Mode.
I follow the instructions to get up to Step 5 on this webpage:
https://kb.netgear.com/24108/How-do-I-configure-my-Nighthawk-router-as-a-wireless-repeater
....then get lost
because I cannot see or find any "Advanced" tab, button or icon to click on.......
Please help!
I am using GENIE.
Sincerely,
schoolbus
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi schoolbus,
Check this KB article below.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to set NighthawkR7000 to repeater mode
> I am using GENIE.
Which "GENIE"? Ever helpful, Netgear uses the name "Genie" for more
than one thing. Netgear routers have a web-browser interface called
"Genie", and Netgear offers application programs for various
computers/pads/phones, which are also called "Genie".
> https://kb.netgear.com/24108/[...]
Use a wired Ethernet connection to set up the repeater unit to
avoid conflicts with the wireless connection.
In other words, use the web-interface "Genie", not a "Genie" app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate the reply, but this advice doesnt answer my question.....
The Genie I am referring too is the App that helps you to configure the router etc.
Can someone tell me what the webpage (see link in my post above) is referring too in its instructions for the Step # that I am stuck at? I see NO advanced tab or button or link.
Also, I cannot hardwire it otherwise I would. WIFI signal interference is not an issue.
Configuring the Netgear Router to be a repeater is the issue I am asking about.
Sincerely,
Schoolbus
- Mark as New
- Bookmark
- Subscribe
- Permalink
To clarify, Genie is a webbrowser interface for configuring the router.
I hope my terminology is correct.
Schoolbus
- Mark as New
- Bookmark
- Subscribe
- Permalink
> router etc.
> router.
Clear as mud. Are you running some Genie app on some device, or are
you running a web browser, and pointing it at the router?
The web-browser interface on these devices has a main page which says
"NETGEAR genie", and has "BASIC" and "ADVANCED" tabs. I don't know what
you are looking at.
> asking about.
And just as soon as you find the web interface, we can worry about
what you want to do with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi schoolbus,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi schoolbus,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
