Reply
How to unbrick the Nighthawk R7000 using OS X and TFTP
Re: How to unbrick the Nighthawk R7000 using OS X and TFTP
Done & thanks again.
Message 26 of 75
antinode
Guru
> [...] I copied the whole file to my desktop versus just the exe green
> file. [...]
   I'll bite.  Which "the whole file"?  And what's a "the exe green
file"?
Message 27 of 75
Mariusthvdb
HI,
thanks youve saved me a lot of headache, after my router suddenly appeared with an unportected LEDE wifi, and was unreachable on all regular addresses. Dont asl, I dont know how this happened.... must have been an interuption of the cable modem setup in the dorm...
all in all I used your guide succesfully to return to the original firmware.
1 addition to be made though: I needed to powerdown the router, and hold the pin, pressing the restore factory settings during powerup, all the way to the green power led blinking.
After that, I uploaded the firmware in 2 seconds !
Might want to add that for reference for other users.
Thanks again1
Model: WNDR3700v1|N600 Wireless Dual Band Gigabit Router
Message 28 of 75
myersw
Master
Thanks for the info.
Glad things are good again. It is a pain to have to do a tftp.
Make sure of two things.
1. Make sure the auto update is turned OFF.
2. Only update the firmware via a PC/MAC Ethernet connected to router and do a manual update.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 29 of 75
westonagreene
Thank you! This got my bricked RBS40 Orbi Satellite running!
I bought it off ebay and it came this way. So glad it's not in the trash--thanks to you.
For those searching the web for a similar woe:
Symptoms: ring was blinking white for about 30 seconds, then suddenly amber, milliseconds, green, black; repeat.
This article combined with the following is what I relied on: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
I found it reading these articles:
https://community.netgear.com/t5/Orbi/Solution-to-fix-Orbi-Satellite-flashing-white-forever-failed/m...
https://community.netgear.com/t5/Orbi/RBK40-Satellite-RBS40-Flashing-White-then-after-25s-rapidly/m-...
https://community.netgear.com/t5/Orbi/Orbi-RBR50-satellite-pulsing-white/m-p/1733449
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 30 of 75
westonagreene
Forgot to add to my reply yesterday, 2019-11-03 05:50 PM, the key that helped me:
pinging the ip address (step 3 of kryptonix's original post). Leaving the ping running, I learned there was a pattern of connectivity and that eventually the connection stabalized. Once stabalized--like 10 minutes after the hold-reset-button-down-while-powering-on step (steps 7 through 9 in kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP )--I was able to do the TFTP transfer.
Message 31 of 75
Fiddlededee
Initiate
@kryptonix I signed up for this community just so I could thank you for saving my evening sir. The binary instruction saved it all. Thank you.
Message 32 of 75
Naive
Moonweasel , I have the same error. Did you figure out how to fix this?
Model: R7000|AC1900 Smart WIFI Router
Message 33 of 75
antinode
Guru
> Moonweasel , I have the same error. [...]
   "same" as _what_?
> [...] Did you figure out how to fix this?
   "this"?  _What_?
   Rather than starting your own thread for your own problem, you've
joined a many-months-old thread with thirty-odd postings.  Pronouns and
other vague references are approximately useless here.
Message 34 of 75
kryptonix
Guide
Glad to help out, that’s where this community is for;)
Senior Designer
Message 35 of 75
Naive
This is my question/reference, it’s the second reply in this thread:
>For me the method still does not work, because in Step 3, ping returns mostly
Request timeout for icmp_seq xx
without the
ttl=100>>
—- Did you get a solution to the above?
Message 36 of 75
Rickrob00
Had this same issue on a nighthawk x6s ac4000, and this was the only thing that worked.  Thanks to Kryptonix!
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 37 of 75
Hossan
Re: Netgear EX6120 wifi extender power light blinking & firmware flash failed
Hi @kryptonix  thanks for your step by step instructions, but that did not work for my device, my Macbook is late 2011 and has an ethernet port so i can connect the router throuh the cable , however i have tried the steps thrugh my terminal which showing ttl-64 (not 100) like urs, when i have typed the command tftp>EX6120-V1.0.0.40_1.0.30.chk after a while it replied Request timed out.what elase can i do?
thanks
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 38 of 75
antinode
Guru
> [...] when i have typed the command tftp>EX6120-V1.0.0.40_1.0.30.chk
   Presumably, there was a "put" command in there?
> [...] after a while it replied Request timed out.
   With my weak psychic powers, I can't see what else you did, but
"Request timed out" suggests that no one is listening at the (invisible)
IP address which you gave to the TFTP client program.
   The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error.  By itself,
saying that you tried it doesn't say much.  Especially when
using a command-line program, copy+paste is your friend.
> [...] i can connect the router [...]
   That's your target/failing device?  That's not a router.
   I don't know that TFTP is supposed to work with an extender, or, if
it did, what the extender's default IP address would be.  And you're
connected to it how?
> [...] what elase can i do?
   Start your own thread for your own problem in some more appropriate
forum?
      https://community.netgear.com/t5/x/bd-p/home-wifi-range-extenders
Message 39 of 75
Hossan
@kryptonix
hi thanks for your intellect description, let me write down a little in details i have uploaded exactly what it happend on my macbook please have a look and provide me a solution, i have followed all the steps you stated. in the ping tab i have got ttl=64 and after tftp>binary i didnt get any OCTET
thanks
Message 40 of 75
antinode
Guru
> [...] i have followed all the steps you stated. [...]
   Not very well.
> tftp> connect 192.168.1.10
   "192.168.1.10" is (or should be) the address of your computer.  Your
computer is not running a TFTP server, so you get a time-out when you
try to talk to it that way.
   You want to connect to the router/other-device at _its_ default IP
address (which, I gather, is that same as for a router: "192.168.1.1").
For example (without the wasted time/steps):
      $ tftp 192.168.1.1
      tftp> binary
      tftp> put <your_file_name_here>
Message 41 of 75
JMGV
I have completed all the process until
PUT firmware.chk
and keep getting "transfer timed out" message.. (see attached image)
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 42 of 75
antinode
Guru
> I have completed all the process until [...]
   Not a useful description of what you did.  _Which_ "the process",
exactly?
> [...] (see attached image)
   Copy+paste of the plain text would be more helpful than a picture of
the plain text, and your picture does not show the initial commands.
However:
      Connected to 192.168.1.10
suggests that you didn't read the previous post:
      https://community.netgear.com/t5/x/x/m-p/1939163#M158111
Message 43 of 75
JMGV
Thanks for the quick reply.
A little bit of backgroud with my problem.. I updated firware to ExpressVPN and after that event I am not able to access the router admin settings. Neither Netgear nor ExpressVPN. As a result, I want to delete the new ExpressVPN firmware and replace with Netgear.
I know expressVPN is 3rd party and Netgear cannot provide support. But I've learned my lesson and what I want is to return to original settings.
Regarding your instructions, new IP address of the router is 192.168.132.140, which I used for the transfer firmware commmand and did not work
Message 44 of 75
antinode
Guru
> A little bit of backgroud with my problem.. [...]
   That would have justified starting a new thread for your different
problem, rather than joining this old, largely unrelated one.
> [...] I updated firware to ExpressVPN [...]
   You might have tried.  It might have worked.  What are the LEDs on
the thing doing now?
> [...] new IP address of the router is 192.168.132.140, [...]
   Says who?  I know nothing, but, as I read the instructions,
installing ExpressVPN on an R7000 should leave it listening at
"192.168.0.1" (which, note, is not what the default would be with
Netgear firmware on an R7000):
      https://www.expressvpn.com/support/vpn-setup/app-for-routers-netgear/
   If the router firmware really is scrambled, and it's scrambled
Netgear firmware, then I'd look for it at "192.168.1.1".  If it's
scrambled ExpressVPN firmware, then I'd look for it at "192.168.0.1".
Anything like "192.168.132.140" _might_ make some sense if the
ExpressVPN firmware is _not_ scrambled, but what do I know?
> [...] which I used for the transfer firmware commmand and did not work
   Regarding "did not work", look (way back) in this thread for "Not a
useful problem description [...]".
   VPNs (about which I know approximately nothing) tend to involve new
(virtual) networks, which may involve different, unexpected
addresses/subnets.  Some confusion may be inevitable.
Message 45 of 75
hornedfrog
Tutor
Thank you, I can ping it but my transfer times out.  Any ideas appreciated.
Message 46 of 75
antinode
Guru
> appreciated.
   Instead of posting a terse/useless problem description in multiple
years-old threads, you might get better results if you started your own
thread for your own problem, and included a few details, such as what
your router does, what you did, and what happened when you did it.
Message 47 of 75
hornedfrog
Tutor
This is not helpful.
Message 48 of 75
kbalaska
I don't have a mac. Would this still work for pc
Message 49 of 75
antinode
Guru
   The details differ.
      https://community.netgear.com/t5/x/x/m-p/1622096
Message 50 of 75
Top Contributors
Discussion stats
Announcements
Orbi WiFi 6E
