Reply
I Can not access my router page.
BrandonDNguyen
Hey, I have been trying to access my router page in order to port foward a specific port. I used to be able to access it all the time and now i can't even go to it. Yes, I have done the default gateway of my cmd, and the website the routerlogin. All i do is type in the default gateway which is 192.168.1.1 into my browser and it just shows the basically refused to connect page on google chrome. Does anyone have a solution to this issue because i really need this to be fixed .Screenshot (3).png
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
BrandonDNguyen
Re: I Can not access my router page.
IT all of a sudden worked now so i am fine now.
Message 4 of 4
All Replies
TheEther
Guru
Obligatory: Are you running Kaspersky?
Message 2 of 4
CAUSE FOUND, being unable to log into router after... - NETGEAR Communities
Solved: Re: Router homepage - unable to connect but can on... - NETGEAR Communities
Among others.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
BrandonDNguyen
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2388 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
