Reply
I am having an issue connecting a printer to a wifi mesh using
branden137
okay using r9000 nighthawk x10 ad7200 router
2x Nighthawk Mesh X6S
printer is EPSON 2750 eco tank
I have deleted all the printer drivers and reinstalled
I am unable to set up the printer for some reason. when i go to set the printer wifi network it shows 3x twinkletwinkle networks available but not matter which i connect to i cannot connect. on my computer/cell/laptop i only show one network name and everything is seemless. i have full bars thruout the house
4k square ft and 1 amazing router and 2 amazing extenders so i have 5 bars every damn place (out of anger i assure you)
and now i cant print
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 5
antinode
Guru
Re: I am having an issue connecting a printer to a wifi mesh using
> [...] when i go to set the printer wifi network it shows 3x
> twinkletwinkle networks available [...]
   Should that name (?) mean anything to anyone other than you?
      https://files.support.epson.com/docid/cpd5/cpd51340.pdf
      The printer can only connect to a network that supports
      2.4 GHz connections. If your router offers both 2.4 GHz and
      5 GHz connections, make sure 2.4 GHz is enabled.
   Are you using the appropriate SSID and passphrase?
   Actual model number?  If those are wireless-network extenders, then
that might help to account for the printer seeing multiple SSIDs (if
that's what you meant).
Message 2 of 5
branden137
NO thats just my network name
both are availeable but because the 2 extenders create a matrix there are 3 of the same ssid
also i am not sure if me using my computer on one of the extenders (wifi) and the printer being on the main routers(wifi) is also causing issues because techniquely they are different even though they are matrixed together as one global ssid/network
the extenders are the
Netgear Nighthawk X6S EX8000 they are triband
Message 3 of 5
AndreyBailey
Hello friend did you resolve your printer issue?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 4 of 5
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 919 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
