Reply
I can't see above .190 in connected devices
AlanSh
I have a large number of devices (45) connected through my router at home. Most are wired and a few are wireless. Everything seems to be working just fine except that when I view connected devices, the table stops at .190. I know I have devices above that IP address (I did check), but they don't appear on the list. I can see 41 devices on the list which is  the number the router tells me are there. But I know there are more!!
So, is there a second page hidden that I can't get at or is there a bug?
Thanks for any advice
Alan
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: I can't see above .190 in connected devices
Are you looking at the attached devices in the app or in the web ui.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 199 views
  • 0 kudos
  • 2 in conversation
Announcements
