Reply
I cant get full speed of my internet connection R7300 DST
Hamzeh_awad
Tutor
Hello
Today i got a new speed from my ISP 150mpbs Fiber connection and my old speed was 100mbps so i made a new speed test on QOS and the only speed i get is 93 mbps and i tryed to speed test while qos disabled and i keep get 93-94 only while i'm the only user on the router !!!
and my router conected to the fiber box with ethernet cable length100cm only ,
while if i made speed test on isp router i get 150mps !
i tryed to made factory rest twice and nothing happend same speed on my laptop and on my phone 94mbps only
and i made this test using wifi and ethernet cable cat 6
and i have latest firmware
so whats the problem now !! how i can resolve this !
Model: R7300DST|Nighthawk DST—AC1900 DST Router
Message 1 of 6
Re: I cant get full speed of my internet connection R7300 DST
Where are you measuring the speed?
LAN connection to the router?
From what? What colour is the LED for the LAN port?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 6
Hamzeh_awad
Tutor
 speed test.net
 yes with cat 6 cable
from the isp modem to the wan port it turn white , if i conecte the lan cable to the port number 1 i get orange led !
the isp moded port is 1 gig btw !
Message 3 of 6
Hamzeh_awad
Tutor
see the attached  pictuer please
Message 4 of 6
This indicates that Port Number one is working at 100 Mbps.
Just another user.
Message 5 of 6
Looks like he could be getting 1GB on his WAN.  The router is certainly capable of this.
@Hamzeh_awad, is it possible the ethernet port on the converter is only 100mbps?
What's in front of the router?  Brand and model of device, please?
I get gigabit on my WAN (Arris Surfboard modem)
Also want to add, the speed issue is not related to the negotiated speed of the WAN port.  @michaelkenward, I know you are aware of this.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1021 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
