- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I cant log into my plug in wifi extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
I forget the username and the password of my plug in wifi extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I cant log into my plug in wifi extender
Write it down?
As a problem description, that easily beats "can't". (Note: "cant"
is a word, different from "can't".)
If you also forgot about the existence or value of its Reset button,
then you might try this radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Reset". Further reading might not hurt, either.
