Orbi WiFi 7 RBE973
Reply
I have also been having significant issues with every single firmware on this device
wholesometrex
Follower
I have also been having significant issues with every single firmware on this device.
I had been having the issues nearly immediately after I purchased the device and then after a few months started looking to understand whether this was a widespread issue.
I found others on the internet indicating that firmware version V1.1.4.6_1.1.85  is the most stable version. I had been running that version for nearly a year or so and just recently decided that I wanted to go and try to get on to the most recent version... however, I still continue to have these wifi connection drops. So I decided to move back to firmware V1.1.4.6_1.1.85 ... and yet... the issues continue after reverting back to V1.1.4.6_1.1.85.
So at this point, I'm very much looking into getting a different device so that I no longer have to worry about the connection drops. Until then... I'm sure I'll continue looking for solutions.
Message 1 of 3
Guru
Re: I have also been having significant issues with every single firmware on this device
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What devices do you have connected?
Did you enable IPv6 on the router after v.88 FW was applied?
Message 2 of 3
Which device would that be?
Unfortunately, telling as the firmware is not much help. We'd have to hunt down for the various devices that might have the same firmware number.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 452 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
