- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I have model c7000v2 modem/router which started blinking the top three light green.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Three weeks ago, my Netgear C7000v2 started blinking initially the top three green and bottom five amber. I reset the modem and now the top three are constantly blinking green. How do I make it work? I search the Internet for all the possible answer but nothing worked. Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I have model c7000v2 modem/router which started blinking the top three light green.
are you able to log into it?
if so, get a screen snip of your cable connections page and your logs and post them back here.
What I'd recommend first, would be to disconnect all devices from the c7000 (even coax) and then push and hold reset for 7-15 seconds. let it fully reboot.
When reconnecting it, connect it right where the coax enters the home. This prevents wiring within the home from being an issue. Also, remove any splitters, attenuators, or amplifiers from the line.
