Reply
I have the netgear 1900 and the cm500
Mpostmanmike
Follower
My set up keeps dropping the internet 3 or 4 times a day sometimes more can anyone tell me how to fix the problem
Message 1 of 2
Guru
Re: I have the netgear 1900 and the cm500
Test a wired PC to the ISP modem and see if anything happens with by passing the router.
Are you wireless or wired when connected to the router when this happens?
What FW version is currently loaded on the router?
Any wireless neighbors near by? If so, how many and what channels are they using?
Swap LAN cables between ISP modem and router. Shortest CAT6 length recommended.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 157 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
