Reply
I need to temporary shut down the 5G part of my nighthawk 1750.
Louwood
Follower
I need to just have the 2.4 side working for a few hours. Any way to shut off the 5G
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: I need to temporary shut down the 5G part of my nighthawk 1750.
   Is that accurate? Not a R6700v2 or R6700v3?  Look at the product
label.  Firmware version?
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for
topics like "Control the Wireless Radios" and/or "Enable or Disable the
Wireless Radios".
Message 2 of 3
Any reason for this?
If it is to set up an IoT thing that demands use of a mobile device on 2.4 GHz, then disabling the SSID broadcast may do what you want.
I mention this because it is a regular request on Orbi devices.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 251 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
