Reply
I think my r7000 is dying after 4yrs of use, now frequently dropping wifi connections
prexactly
After 4yrs for good use and functionality, my r7000 is now frequently dropping wifi connections and making high pitched noises (intermittently).
Now attempting a default factory restore (and maybe a firmware downgrade?) to see if that helps, otherwise looks like it might be time for a replacement.
Any advice and/or recommendations?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
myersw
Master
Re: I think my r7000 is dying after 4yrs of use, now frequently dropping wifi connections
You did not indicate firmware version. I am guessing latest, 10.0.9.64. This version has issues.
Would suggest you back rev to 10.0.9.42.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 3
prexactly
Yep, was at latest (1.0.9.64).  I'll give 1.0.9.42 a try.  Thanks!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 660 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
