Reply
IPAD OpenVPN Client Installation Without iTune
As the title indicated, it will be really helpful if I could install the OpenVPN client to an iPad (latest iOS) without using iTune. Please let me know if there are anyway to do that. Thanks!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Master
Re: IPAD OpenVPN Client Installation Without iTune
Message 2 of 5
Master
Hi mmnnbb,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 5
It did not answer my question. I would like to know how to install with iTunes. Who still use iTunes in another computer??
Message 4 of 5
Guru
Don't really understand your query here. To install the OpenVPN Connct App you don't need iTunes on a computer - this can be done straight away from the App Store.
Suspect you are struggling to upload the ovpn config file. You can do this for example by using Dropbox. Done this for some freinds earlier this year, when I remember right: First push the file to Dropbox. Then open the Dropbox app on your iOS, select the file, and then export -> choose the option [Open In] and then [Copy to OpenVPN].
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1608 views
  • 0 kudos
  • 3 in conversation
Announcements
