Reply
IPV6 on LAN not available on R8500
mnuptown23
I used auto-config to enable IPV6 on my R8500. I received an IPV6 address on WAN. However IPV6 on LAN keeps coming back at not available each time I refresh. I'm running the latest firmware for the R8500. Would appreciate any guidance on how to resolve this issue. Thanks.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 7
Guru
Re: IPV6 on LAN not available on R8500
Is IPv6 enabled under Advanced/Advanced Settings/IPv6?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 7
mnuptown23
Yes, I enabled IPV6 in Advance Settings and used auto-config to set it up. I get an IPV6 address on WAN, but not on LAN where it shows not available.
Message 3 of 7
Guru
I presume you have IPv6 enabled on the NIC on the PC or device that support it?
If so, I recommend you contact NG support and see if there is any additional information regarding this...
Message 4 of 7
mnuptown23
yes, IPV6 is enabled on my PC. Thanks.
Message 5 of 7
JamesGL
Master
Hi mnuptown23,
Is your IPv6 from ISP for both WAN and LAN or WAN only?
Message 6 of 7
JamesGL
Master
Hi mnuptown23,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1321 views
  • 0 kudos
  • 3 in conversation
Announcements
