- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
IPv6 Help Document Typo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware: 1.0.3.10
On the Netgear Admin Page -> routerip/adv_index.htm -> Advanced Setup -> IPv6
When you click help at the bottom it descirbes the vairous help stuff for the page.
On the IPv6 page there is a typo describing the two options for IPv6 (DHCP / Autoconfig)
"You can select how you want to assign IPv6 address to the devices on the LAN (i.e. your home network). You can use either the "DHCP Server" or "Auto Config" to assign IPv6 address. Using DHCP Server may pass more information to LAN devices, but some IPv6 systems may not support the DHCv6 client function. "Auto Config" is used by default."
The underline item should be DHCPv6
Same mistake on the KB page too: https://kb.netgear.com/24008/How-do-I-use-auto-detection-to-set-up-an-IPv6-Internet-connection-on-my...
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: IPv6 Help Document Typo
Hi computeronix,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
