Orbi WiFi 7 RBE973
Reply
Improvements to the D7000v2 and possibly others
raviw
Hi..
The D7000v2 has the ability to use 2 Wan connections. DSL and PPPOE. I use one as the main one and the other as backup. If my main connection goes down it is a pain to switch to the other because I have to do 2 things.
1. On the Internet setup screen I have to reenter my username/password for the ISP. Not only is reentering the login details a pain but doing this causes the Wifi to drop and reconnect. So wastes time.
2. From the WAN setup I must switch the connection. Causes router to reboot. Again wastes time.
Is it possible to update the firmware so that both usernames and passwords are remembered and I simply have to switch the connection type? If it isn't possible to avoid the reboot that's fine but atleast I don't have to reenter my login details.
Thanks in advance.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
Re: Improvements to the D7000v2 and possibly others
Wrong place for that request for several reasons.
The D7000v2 is a DSL modem/router. This place is for plain routers.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section. That's probably here:
DSL Modems & Routers
When it comes to feature requests, there's another place for that:
Idea Exchange For Home - NETGEAR Communities
Message 2 of 3
raviw
Thanks. I'll post there.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 365 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
