Reply
Incorrect connection icons shown in attached devices
Stressed101
Follower
The connection type shown in some "Attached devices" is incorrect?  Some devices on WIFI show up with the "ETH" icon rather than "WIFI"
This is on an R9000 with V1.0.4.2 f/w
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Incorrect connection icons shown in attached devices
Netgear is aware of the issues with the attached devices on the R9000 and are working on a fix.
DarrenM
Message 2 of 4
sougato
ETA on when this fix will be available? I have an R7000, and it's never worked in the 2 years I've owned it. I keep seeing "we're working on it" in various posts, but how long does it take to get it right? Why even have the "connection type" if it's wrong?
Message 3 of 4
IrvSp
Master
@sougato, I think common code is used for All/Most routers... my R8000 has the same problem. I have found that on my iPad I can change them using the Netgear (since depricated) or Nighthawk app and those changes hold when I look on the Browser GUI. Possible not all will hold but worth a try if you can do it. Suspect the Android versions would work too.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 464 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
