Reply
Incorrect password only for 2.4ghz
Erikahen1200
Hi!
I received an incorrect password pop up on my phone about a month ago only for the 2.4 network. After changing passwords, then back to the original (so i didn’t have to change it on devices connected), did it work. It’s been working for the past few weeks and again is now not connecting due to “incorrect password”. It is indeed the correct, factory set password.
I believe this time it’s only for new devices, not ones currently connected to the network. We just got a Roku I’m trying to connect to the 2.4 because it’s far from our router
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Re: Incorrect password only for 2.4ghz
The first thing to do is to ignore the router and to get the phone to forget the connection to that wifi source. Then start the connection from scratch.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Erikahen1200
Thanks, but it’s not the phone. It’s a newly set up Roku. It happens on anything.
But I did try that last time with the phone and it didn’t work.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 570 views
  • 0 kudos
  • 2 in conversation
Announcements
