Orbi WiFi 7 RBE973
Reply
Infamous D7000V2 disconnection issue
SigueSigue
Tutor
It seems a lot of the posts I've been reading on the D7000v2's disconnection issue - where the router is running, but devices connected to it lose internet, and when you disconnect and reconnect it either disappears or refuses connection, are all using firmware above 1.0.0.51
has anyone acheived any stability with this device ever? and if so which version of firmware are you running.
Ive seen posts about changing the channel or changing the MTU size or downgrading the firmware. What's the answer folks?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 480 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
