Reply
Install R8000 to Vivinit ISP
Cabt2217
Anyone been successful installing an R8000 to Vivinit ISP? I can't get the router to connect to internet!
Message 1 of 4
Retired_Member
Not applicable
Re: Install R8000 to Vivinit ISP
Have you bypassed their router and tried going direct with a PC?
If yes and it worked login to r8000 setup...internet setup and select use PC MAC address
Message 2 of 4
Cabt2217
Thanks but i have tried that. I can connect directly to my MAC so I went into setup and tried this. In the router log it appears to be trying to connect but then disconnects right away. Can't keep the connection. Any other ideas?
Message 3 of 4
Retired_Member
Not applicable
None other than try power cycling the radio
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1428 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
