Reply
Installation
Allen64
Follower
Installation
I needed to put some wifi signal in my shop, I currently have a Netgear Nighthawk R7000 in my house, I want to move it to my shop and put the new Nighthawk R8000 in my house.  Can I hard wire from the internet modem to the R8000 then to the R7000 in my shop? If I can where do I connect from and too? Is there any programming or switch setting to do?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
antinode
Guru
Re: Installation
> in my shop? [...]
   Yes.
> [...] If I can where do I connect from and too? Is there any
   Visit http://netgear.com/support , put in your model number
("R7000"), and look for Documentation.  Get the User Manual.  Look for
"Use the Router as a Wireless Access Point".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 151 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
