Orbi WiFi 7 RBE973
Reply
Installing USB Device(s)
cadguy82
There is only 1 usb port.  CAN YOU INSTALL A PRINTER AND AN EXTERNAL DRIVE TO THE NIGHTHAWK AC2400 AT THE SAME TIME using a 4 port usb connector?
Model: AC2400|Nighthawk AC2400 Smart WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Installing USB Device(s)
It is not suggested but if you do make sure the USB hub is powered.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 286 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
