Orbi WiFi 7 RBE973
Reply
Insufficient Coverage for R8500
srstrunk
Follower
I bought a Nighthawk X8 for a very large home in hopes of complete coverage.  How do I extend coverage in the house?  Can anything be added to the system in the area of the home that does not have coverage?  I have ethernet in several places in that area that comes back to the same location the R8500 is located as well.
Message 1 of 5
Accepted Solutions
netwrks
Master
Re: Insufficient Coverage for R8500
You can purchase another router that supports Access Point mode, or the EX7000, which makes a great AccessPoint. Just configure the device from your laptop / desktop, cable up the device to your base router and you have further wireless coverage into your home.
Message 2 of 5
All Replies
netwrks
Master
Message 2 of 5
LJ111
using the R8500 could a R8000 be used in place of the R7000?
Message 3 of 5
netwrks
Master
If you mean does the R8000 support AP mode. The answer is yes. Use whatever you need.
Message 4 of 5
LJ111
Thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3185 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
